Pulling certain Parameters into a schedule.
stapelbergp
Message 1 of 25
stapelbergp
Good day all. I have a project with multiple furniture families. Each family has s few parameters that get added to a schedule. There is just 1 parameter that just does not want to show up in the schedule.
I have attached images of what is on my screen. I have also tried to add it via project parameters but still nothing pulls through.
Any assistance would be appreciated.
Replies (24)
Message 21 of 25
stapelbergp
The moment I linked that to the unit identity parameter of the family, the data pulled into the schedule
Message 22 of 25
So, basically the Parameter Field WAS is the Schedule but the cells under the Parameter Field column were empty because there was no data entered.  Pretty much what I explained before.  You need to enter data yourself.  And you did finally by assigning a Global Parameter to it. That one way to do it. Good job.
Message 23 of 25
stapelbergp
So I wasn't that successful. Now every time I link a new family to the "Unit Identifier" parameter, it pulls in the info from the first family.
Message 24 of 25
Why do you associate the family parameter to a global parameter?  It is the wrong way to fix your problem.
Message 25 of 25
stapelbergp
I managed to create a shared parameter ans add it to all of the families in the project. Worked perfectly.
