pull down in schedule
jostroopers
jostroopers
I want to extend the pulldown menu with an item in a schedule under the column Description .
There are now three items in the pull down menu.
Can someone explain to me how I can add a component in the pulldown menu?
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
FGPerraudin
Just type a new value in, and it will add it to the dropdown!
(the dropdown in that case just lists all the already used values...)
François
Francois-Gabriel Perraudin
BIM management and coaching
jostroopers
Hi Francois
When i do that it overwrites the value.
The new value will be added and the other value disapears.
I get the message: this change will be applied to all elements of type...
Mvg Jos
FGPerraudin
Yes, it shows only the values that exist in the project.
If you replace a unique value, it will disappear
FGPerraudin
You get this message becaus you have unticked the "itemize every instance" in the Sorting/grouping tab of your schedule settings.
So it applies the change to all the the grouped elements.
François
jostroopers
I found it, it was placed under the wrong catergory.
Thanks.
Mvg Jos
chrisplyler
You can get that message either because you aren't itemizing every instance, OR because you're changing a Type Parameter.
