Property Line Issue
Property Line Issue
Message 1 of 19
Property Line Issue
Greetings:
I'm trying to get the sum of all property line segments (perimeter) into a tag. I created a Property Schedule with a Distance column and set the column to calculate the total, so I have the perimeter number but do not know how to get it into a tag.
First time poster here.
EJ
Replies (18)
Message 2 of 19
planner_matlabi
Hi
Please Create a New Post in Architecture Froum
and Send picture , your Project and Tag and Schedule
Message 3 of 19
You need to push that value to a Shared Parameter attached to Property Line properties. Then your tag can read that Shared Parameter value. Do you understand the concept/proceedure?
Message 4 of 19
I created a shared parameter and named it Perimeter. I don't know how to get it to sum the property line segments. I've yet to grasp the different parameter types and their usage.
Message 5 of 19
Well, first off: did you add that shared parameter to the Property Line properties? In other words, when you select a PL, does the shared parameter name appears under the PL's instance properties?
Message 6 of 19
I have the shared parameter as a column in the Property Schedule but I think I need help with the formula. I have Distance in the formula but can't get the sum. I know the Excel function to use but not the Revit function.
Message 7 of 19
Sorry. Maybe I misunderstood. Post your rvt w/ schedule.
Message 8 of 19
Yes I think the shared parameter is setup properly.
Message 9 of 19
Just create a property line schedule to get the sum of segment lengths, format it to show only the final number, and place it on sheet next to the property line to imitate a tag.
Message 10 of 19
Funny. I'm reading this differently than you @ToanDN. I think he's just looking for a calculation parameter in his schedule.
Message 11 of 19
Do I just have to add Distance to the SP column and total the column? No formula?
Message 12 of 19
Save me some work here @Anonymous. Post your rvt w/ schedule and we'll show you how.
Message 13 of 19
Thanks ToanDN for the reply and what you suggested will work but I also need to use the perimeter in regularity calculations.
Message 14 of 19
Don't know how to post the schedule. Sorry.
Message 15 of 19
I only added Distance field to the schedule, set it to calculate total and un-itemize all instances to group them into one cell.  What does the later part of your sentence mean?  Why would this method prevent you from doing it?
Message 16 of 19
From the way I understand it, you have created a formula to calculate the perimeter of a closed Property Line (e.g. the sum of all the individual property line segments that form the closed boundary), and now you want to push that calculated value to a shared parameter field that the a Property Line Tag can read and report.
Am I warm?
Message 17 of 19
@Anonymous
See the attached Revit file.
Message 18 of 19
@Anonymous: I'll use @ToanDN's work to thrown down my interpretation.
Message 19 of 19
travisUGWFP
What if there is more than one property? And how do you calculate the perimeter automatically?
