PROPERTY BOUNDARY LINE VALUES
Message 1 of 9
I WISH TO KNOW IF IT IS POSSIBLE TO SHOW VALUES OF A PROPERTY LINE IN DEGREES MINUTES AND SECONDS BY SIMPLY CLICKING ON THE LINE?IS THERE AWAY OF ANNOTATING ANS INDICATING THE DIMENSION AND ANGLE VALUE AS SHOWN ON CONVENTIONAL SITE/SURVEY PLANS?
THANKS
Replies (8)
Message 2 of 9
ryan.duell
You can create a Property Line Segment tag by:
1.  R > New > Family > Annotations > Generic Tag > change Family Category and Parameters > Property Line Segment Tags.
2.  Add desired label under Home > Label > choose Parameter[s].  Load into Project.
3.  Annotate > Tag by Category > click on Property Line
The tag should indicate the value you specified in the Label [in the tag family] and display this in the tag.
Please let us know if this helps.
Thank you,
Ryan Duell
Message 3 of 9
Many thanks Ryan.
I shall follow this process.
Message 4 of 9
Is there a way to change the distance parameter in the label to decimal feet eg. 82.00' instead of 82' - 00". I have tried changing the units in the family and in the project but I get the same result. this is the result I would like to have. :[N 18%%d 42' 00" W 82.00'] instead of [N 18%%D 42' 00" W 82' - 0"]
Message 5 of 9
Change the tag family label Units Format to Decimal Feet with 2 decimal spaces.
Message 6 of 9
I don't have a units option in my label type properties
Message 7 of 9
Message 8 of 9
Thank you! I did not know that was there once you highlight the parameter.
Message 9 of 9
Very helpful, thank you.
