AutoCAD 2014,
I am missing my Properties Palette. I was working in the program, didn't see myself click anything in particular and it just disappeared. I tried getting it back by the usual ways on the ribbon on the top of the screen and the other suggestions AutoDesk makes, but it has not come back. I saw how other people suggested you may have gone from two screens to one, but I have been using the same one screen for 2 years now. I asked other Revit friends if they know a solution but every suggestion they made did not work. I have wondered if it is off in space somewhere but don't know how I would find it if it is.
Suggestions or help would be appreciated.
Brittany
try the following:
type PP to see if it toggles on/off...it may be off
verify in View Tab of Ribbon, User Interface, Properties is checked
change display resolution from current to something fat (1280 x 1024 or less)...everything will resize...may see the properties palette then
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
lastly, try resetting revit user interface...
For Revit 2014 you can reset the interface by following the steps below:
Reference the section on “Project Browser” from the link above – this will hopefully help both palettes.
Hopefully this will bring it back to the default state – let us know!
