proper/typical method to insert civil CAD to generate revit topo then place model at that elevation
jledgewood409
jledgewood409
there is a confusion/debate on how to insert the civil CAD drawing which we will generate the revit topo from and then subsequently place the model at that elevation.
we begin modeling our building/home and after that we will get a civil drawing that is CAD and has topo lines at the correct elevation e.g. 8,000 ft. (sea level). we insert the CAD and then go through the process of generating the topo from it. so now our topo is at 8,000 ft. and our building is at 0 ft. now we use the 'relocate project' tool and in an elevation move the building in the Z direction to the 8,000 ft. now our levels read the 8,000 ft. but for some reason the topo moves up 8,000 ft. as well. there is something going on that i cannot figure out. some step i am missing.
jledgewood409
i forgot to list the version of revit. i am using revit 2021
If you want topo and building in the same file:   Link CAD file in center to center, move it to your building, acquire coordinates, generate topo.
Of you want topo and building as separate files:  Link CAD file in a new Revit project origin to origin, create topo, save as Site file, link site file in building file center to center, move to match building, acquire coordinates.
Have a good read:
https://s3.us-east-2.amazonaws.com/pfacs.downloads/Conferences/Aubin_HAND_2015_RTC_Shared_Coordinate...
