Project won't rotate back to project north from true north
skyeg321
skyeg321
Hey all, I have something very strange happening that I haven't seen before. Upon opening the project the project is set to project north and when I change to true North it does rotate correctly but when I then try to change it back to project north it won't go back. Has anyone experienced this before? This is a bim 360 hosted project in case that matters.
So, to clarify, you're talking the View "Orientation". You can toggle between "True" and "Project" North, but it does nothing when you do; right? And, you are certain the Project Base Point has an Angle to True North; right?
skyeg321
Yes thats right. I think we can use the workaround. Thanks!
