Project parameter grayed out in properties pallet
Message 1 of 10
Hello, currently my project browser is bit messy. so I planned to create sub-discipline folder so that I can move some of the secondary plans.
Initially, I created a project parameter Sub-discipline but it has been grayed out in the properties pallet. I cant enter any values.
can anyone please help me to fix the issue.
Replies (9)
Message 2 of 10
ennujozlagam
hello, did you assigned your parameter data into categories VIEWS? thanks
Message 3 of 10
Yes! please find the attachment.
Message 4 of 10
ennujozlagam
Maybe change the group parameter under - identity data and see if helps. Thanks
Message 5 of 10
Hii. I changed as Identity data. still,l it's the same.
Message 6 of 10
Alfredo_Medina
Most likely the view that you are trying to change is controlled by a view template, and that new parameter is checked as "included" in the settings of the view template. If that's the case, go to the settings of the view template that is assigned to the view, scroll to the bottom of the list, find that parameter and uncheck it from the "Include" column.
Message 7 of 10
ennujozlagam
I think @Alfredo_Medina is correct. It controlled by your view template lift lobby detail, try to set to none. Thanks
Message 8 of 10
kristdan
Community Visitor
Community Visitor
Yep saved.
Template ON
Message 9 of 10
cnupsonYBUUR
Community Visitor
Community Visitor
I had my project browser parameter organized by Constraints and now it is gray. Could this happen because I saved from the cloud to my desktop? I tried creating another browser and placed that under Identity Data but it is still gray. Not sure why. Can you help?
Message 10 of 10
Your View Template control that parameter.  If you want to change that parameter value per View, edit the View Template and untick the box next to that parameter name.
