Project north
Project north
Project north
I have a project where I have already set up my project north and true north but now I wish to change the project north. I have already drawn my base plans. what is the easiest way to go about this.
The reason I want to change this is because it will not fit on a sheet vertically and when I do the 90 degree rotate the text turns as well which I dont want.
Let me know if there is another way to do this!
chrisplyler
Thank you!
chrisplyler
You're very welcome! If my previous post did indeed solve your problem, then please select it as a solution.
