Project North Problem
Message 1 of 12
Hi All, I've set up Project North on my project and for some reason only one of my views will rotate to Project north, all the others just stay as they are, anyone else encountered this issue, did you resolve?
Thanks.
Replies (11)
Message 2 of 12
syman2000
Check and see if you have other that set to true north.
Message 3 of 12
Yes, i have the view's set to project north but only one of the views actually rotates to project north.
Message 4 of 12
syman2000
Check and see if you have scopebox set to none.
Message 5 of 12
scope box is set to None
Message 6 of 12
syman2000
Did you or any of your teammate rotate the viewport crop? See if you can select the viewport crop and rotate it.
Message 7 of 12
no I haven't rotated the viewport crop nor has anyone else.
Message 8 of 12
syman2000
Upload the file so we can take a look.
Message 9 of 12
Thanks, I can't upload file as this is a defence project.
Message 10 of 12
You set up "Project North"?  Do you mean "True North"? In other words, you set the "Angle to True North" in the Project Base Point Properties?
Also, Orientation (e.g. Project North, True North) is a Plan View Property, not a global setting.  So, you need to set the Orientation for each Plan View.
Message 11 of 12
jon
Did you ever get a solution to your problem? I've got what sounds like the same issue, four years later than you had it, in Revit 2024. One view rotated project north as I wanted, but none of the other plan views will rotate.
Message 12 of 12
azad.Nanva
@jon
you should set the Orientation of other view to True North.
