Project Cannot be Opened [Elements Missing]
PaulK
Message 1 of 8
PaulK
I am hoping someone helpful can help me. I have just completed a project which I am looking to send out today however at the last second, as I hit prrint, Revit crashed and now I can't get the project to open! I get an error at 52% saying there are too many elements missing, please contact Autodesk Support. I have placed a call request for tomorrow which is not going to help me issue the drawings today 😕
Does anyone have any experience with this issue and know a solution? The model is a workshared file, i have tried restore back-up (same error) and opening local files from my PC and copying the file and detaching from central... All give me the same error report.
Replies (7)
Message 2 of 8
ennujozlagam
Hello, have you try to tick audit before opening the file? or you can check these LINK and LINK maybe can help you then. thanks
Message 3 of 8
PaulK
Thanks for your response! Yes, I have tried to audit - no luck. I am trying R2017 as the project is in 2016. This was a suggestion in the first link you posted... Fingers crossed.
Message 4 of 8
jayhar
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/revit...
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 5 of 8
You're trying what? Sounds like you're saying that you're trying to open a 2017 Revit Project in a 2016 version of Revit.  Of course, that's impossible; so what do you mean by: "I am trying R2017 as the project is in 2016".
Message 6 of 8
PaulK
I am trying to open the 2016 project using 2017 in the hope that the upgrade fixes the problem - It doesn't 😞
Couldn't do it the other way could I 😛
Message 7 of 8
PaulK
I received a call which I scheduled from Autodesk and sent the file to them. The guy (who was very helpful - thankyou) was able to open the project for me using tools a pleb like me can't have and sent it back. A few walls and all the roofs were deleted so a minor fix was required and the project was issued a day late with no actual solution or reason for the issue to avoid it happening again.
I guess if you have a similar issue and are looking for a fix, there may not be one so contact Autodesk asap to get help from support.
Message 8 of 8
Viveka_CD
Hi @PaulK
Thank you for the response.
Case #: 14513795 is your tracking number and I saw that your model has been fixed using internal tools.
See this thread for good practices to prevent element corruption:
AKN articles
Missing elements
Revit Error: Too many elements missing when Audit is Checked
