Project Browser in Mechanical Drawing
PhilvK
Advisor Advisor
PhilvK
I created an HVAC drawing using the Mechanical template. The 1st and 2nd Mech Plans are under different categories in the Project Browser, and HVAC is listed twice. Can someone please point me to a video or tutorial that covers the basics of how this browser organization is supposed to work and so I can correct whatever i am doing wrong? I'm using Revi 2021 and this is only for coordination - not for a full blown engineering model.
Accepted solutions (3)
alan_eu
You have your Navigation Project Browser organized by Disipline and by type (or something like that) and you have the views with the same type, duplicated with different category. You must change the 2 - Mech view to Mechanical Discipline.
You can see that organization with right click on the Views (Discipline) name.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
RDAOU
@PhilvK
  • Coordination & Mechanical are Disciplines (Built-in Parameter)
  • HVAC is a Sub-discipline (Project Parameter - Views/Project Browser sorting)
When you sort by Discipline, the sorting is Done by Discipline / By Sub-discipline / Family-Type...in your case
Floor plan 1-Mech is set to Discipline: Mechanical -  Sub-discipline : HVAC  - Family & type: Floor Plan
Floor plan 2-Mech is set to Discipline: Coordination -  Sub-discipline : HVAC - Family & type: Floor Plan
To list all under the same tree branch:
  1. EITHER Select or open floor plan 1-Mech and set it to Coordination (If as stated in the OP all are coordination)
  2. OR Select/Open floor plan 2-Mech and set it to Mechanical (if all need to be Mechanical)
Difference between Coordination and Mechanical would be the visibility of other non-mechanical model elements
PhilvK
Thank you folks for your comments, that worked for the plans, but I absolutely need to study this more as I really don't understand how the browser is groupie and sorting.
Wile we are on the subject of Mechanical plans, is it possible to draw a sloped section of duct by starting at one elevation as selected on the option bar, and ending at another elevation by selecting a different height? I can get a vertical offset OK, but can't draw a sloped section of duct.
RDAOU
@PhilvK
You mean like this??
  1. Place any section...Vertical or horizontal
  2. then select the section and use rotate
  3. Uncheck copy
  4. place center at the intersection between Section line and Center of duct...
  5. then rotate to align
PhilvK
Thank you for this, although not what I was looking for. I was hoping that it was possible to specify a starting point height for a duct, then specify a different ending height, all while in plan.
RDAOU
@PhilvK
Sorry, I have mistaken section/Segment of a duct for a view section....
In plan view you should be able to  edit the elevation at start and end on the plan view only after placing it not while placing.. Otherwise place in section views
