Project Browser and Properties Palette Freezes
ejones422
ejones422
What is the recommended fix, when the Project Browser and Properties Palette freeze in Revit but not the drawing window or it's elements.
dzanta
this may be a graphics driver issue...verify your card is certified for revit and using the proper driver
do a repair on revit if necessary
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
graeme.turnerX679H
Hi, this has started doing this with myself running Revit 2024 v 24.2.0.63. Project browser completely freezes and cannot select any views or sheets etc. All other tabs, etc work fine. Any update on a solution. Graphics card running latest drivers etc. Never happened before now.
graeme.turnerX679H
ladair
Did you ever get a solution for this?  We are experiencing the same issues since moving to Revit 2024
graeme.turnerX679H
Nope, still have same issue. Project Browser freezes in 2024. I re-installed software twice and still same issue. Need a fix for this as having to restart Revit every time it happens is really disruptive.
