Project Browser and Properties Frozen
Message 1 of 74
My computer crashed earlier today and since i've started up Revit again my project browser and my properties have become frozen. I can maximize and minimize them but i cant move them anywhere or click on anything thats in them.
I've rebooted and also run a repair but no luck.
I've searched countless forums and cant seem to find anything relating to the problem and revit is unworkable without these 2 items working.
I'm running Design Suite 2014.
Any help is appriciated.
Accepted solutions (3)
Replies (73)
Message 61 of 74
THANK YOU, OMG.
Revit 2016
-View Tab, User Interface, Browser Organization, Sheets, check 'sheet prefix'
Worked Perfectly, Project Browser is now unfrozen.
Message 62 of 74
Glad it worked for you. I have had numerous replies on that one!
Message 63 of 74
rubiomarisela
Community Visitor
Community Visitor
OMG Thank you so much That worked!!!!
@Anonymouswrote:
I have just gone through this issue on 2015.
I tried the 'successful' link and did not get the intended outcome. not sure if the same process for 2015 applys.
The method I used to unfreeze my project browser were as follows:
1. Open 'User Interface' under View tab.'
2. go down to 'Browser Organisation'. This is where I changed a preference. Under the Sheet tab I changed the preference to 'Prefix' ( i'm sure any tick box would event in the same outcome). Apply and OK.
This updated in my project browser which had also unfrozen my project browser . I then went through the same process to change my preferences back.
All working again!
Message 64 of 74
Solved for my Revit 2016, TY!!
Message 65 of 74
Just wanted to point out the options referred to here is under the big R in case anyone else had to look a little bit. Opening the options dialogue worked for me too after some initial hair loss. Thanks!
Message 66 of 74
OMG! It helps. Thank you so much.
Message 67 of 74
Glad to help!😎
Message 68 of 74
Oh CHaskings I want to kiss you!  Assignments due this week and this happened and I was beside myself.  You have saved my year!  Thank-you thank-you a thousand times thank-you!
Message 69 of 74
The same thing just happened to me with 2018 and this did the trick.
Thank you very much!
Message 70 of 74
Awesome solution. I reset my project browser in a few seconds... Thanks
All working again!
Message 71 of 74
This worked for me. Revit 2018- Properties and Browser locked up. Switched the view settings and then switched it back to all and it reset it.
Message 72 of 74
jonathanroy8676
Thanks Al 🙂
Message 73 of 74
worked 😊
Message 74 of 74
mert.ayangolu
This is year 2023 and the same problem still happens even in Revit 2024. Thankfully @C.haskings method still works!
