Product Support
Product Support
kesslercWEK8Q
Message 1 of 11
Product Support
kesslercWEK8Q
Does Autodesk still support Revit 2023?
Replies (10)
Message 2 of 11
RLY_15
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Which-are-the-offi...
Revit 2027 will be out in a few months at which point Revit 2023 would rotate out.
Message 3 of 11
Basam.Yousif
Yes - but might end in few months. What do you have?
Make sure your download the installer and all updates while you still can.
Message 4 of 11
kesslercWEK8Q
I will need to get the installer then.   I have an older system that requires Revit 2023 or prior to actually function with the older AutoCAD the system needs.   I have tried to get it upgraded but the AutoCAD has to be 2022 and it looks like Revit 2023 is as far forward as I can go before the older versions of AutoCAD do not work with it.
Message 5 of 11
Basam.Yousif
What specific products are you looking for? I will share links here if I have them.
Message 6 of 11
kesslercWEK8Q
@Basam.Yousif Revit 2023, please!
@kesslercWEK8Q - this post has been edited to add user tag.
Message 8 of 11
rosie_lucas1
Hello @kesslercWEK8Q ,
Did the information provided by @Basam.Yousif  help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
Message 9 of 11
kesslercWEK8Q
Thank you so much!!!!
Message 10 of 11
Basam.Yousif
You're welcome.
Make sure you download everything and save it.
Message 11 of 11
kesslercWEK8Q
Hey, guys... came up with an error installing Revit 2023.. what are we missing?   (I attached error)  We are using the current update for Win 11.   Maybe a dependency?
Thanks guys!
