Revit 2025 crashes right after clicking on "Open" in the Start screen of the software.
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
AlexCleysson
1012 Aufrufe, 5 Antworten
Revit 2025 is crashing when I try to open a file via the "Open" option in the starting screen. I can open files directly from their folders, though. But when I try to save it, it also crashes. I will link the journal txt file that the software generated. Maybe someone can help with this.
It's happening only in the 2025 version. I installed the 2023 version, for instance, and it's working fine.
Tags (3)
Beschriftungen (3)
5 ANTWORTEN 5
Nachricht 2 von 6
SteveKStafford
als Antwort auf: AlexCleysson
Your journal notes the following exception and closes: ExceptionCode=0xe0434352
If you search Google for that you can visit this page, it might help?
Steve Stafford
Nachricht 3 von 6
AlexCleysson
Thank you for the help! I'm currently trying some of the suggestions. Nothing fixed the problem yet, but i'll keep trying. I will report back soon.
Nachricht 4 von 6
AlexCleysson
als Antwort auf: SteveKStafford
Nachricht 5 von 6
AlexCleysson
I've tried just about everything in the list and the 2025 version is still not working. I guess I'll have to wait for a new Windows or Nvidia update. Thank you very much, anyways.
Edit: I searched a lit bit more on the subject, and found a solution, or at least "sort of". I uninstalled "Microsoft SQL Server 2014 Express LocalDB" and now it's working fine. I don't know if it'll affect other softwares, time will tell.
Nachricht 6 von 6
meganrease
I am having the same issue where my Revit 2025 won't open at all and it crashes I think due to the Revit 2025.4 update? Atleast thats what is says when sending a report.
