- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working to produce 3d cad-material of the products my company manufactures and sells. The demand requires that there's 3d dwg and Revit families of the products. Our R&D uses PTC Creo and straight conversion to 3d dwg is not an options. I was planning to model everything in AutoCAD and then use the 3d dwg files to build the Revit families.
Today I found this page with best practices for modeling Revit families. This line got me questioning my approach to the task:
"If starting with a DWG or SAT file, these should only be used as a reference for the creation of native Revit geometry, and then removed from the family. Imported data can cause performance issues in Revit models."
Is the Revit modeling engine really so different from the one AutoCAD uses that it would be worth to model the families again in Revit? I will most likely have to do all the work by myself and modeling our complex products twice is a huge task.
