PROBLEMS WITH WORK PLANES - PART 2
B] Because of HAVING PROBLEMS WITH WORK PLANES [PART1] I have had problems adjusting the height of STACKED WALLS
1] I have two Stacked walls of similar structure.
2] Both Stacked Walls BASIC and GATE have the same Five walls in the Stack.
3]Types 1 and 2 - 4 and 5 have the same heights in both Stacked Walls. The height of Type 3 is set to variable.in each
4] I assumed that the overall height of each stack - Basic and Gate - would be set by assigning a Height value in the SAMPLE HEIGHT box in the top right [again images 7 and 8]
5] I did this but when inserting the Gate Wall [ see position in image 6] the Gate Wall although assigned an overall height of 5150 came in at exactly the same height as the Basic Wall. NB image 6 shows it finally adjusted]
6] I then tried to cross-check the height of both walls by drawing a Section through the Gate Wall but I was unable to query this Section though I was able to adjust each wall's height but NOT IN A CONTROLLED WAY - ie using model/ref lines etc.
7] I then drew a Reference plane along the line of the Section perpendicular to the Wall and was able to get started/use model/ref lines etc
8] Isn't this a very VERY long-winded way of working with a Section?
I hope this makes sense
Images and Simple WorkPlane project [Image 5] attached - NB I haven't attached the Town Wall project
