Problems with topo surface triangulations
Per.Eliasson_Mondo
Message 1 of 9
Per.Eliasson_Mondo
Ripping my head of soon! Revit is by far the worst software ever created with modifying topo surfaceses. Ive created a surface in civil 3d and trying to insert in Revit. Should be easy but it isnt at all.
Getting this problem for example. how the H*LL do I get this line deleted?!?! There is no reason why revit should draw this line at all. Anyone here that is better than me at doing this? I know civil 3d, but this just pisses me of! haha
Replies (8)
Message 2 of 9
Contour?
On Site&Massing Tab.
Message 3 of 9
Message 4 of 9
Did that turn your frown upside-down?
If not, beer works too.
Message 5 of 9
one more for you...
Message 6 of 9
lucdoucet_msdl
@Per.Eliasson_Mondo
I suspect that the points along the curb are the outermost points of the toposurface.
In a plan view, if the curb curves inward towards the center of the surface, Revit's algorithm will enclose them by connecting the outermost points.
The solution would be to add a point outside the added edge and then split the surface.
-luc
Message 7 of 9
Per.Eliasson_Mondo
Solved it! I did as you told me about splitting it. But I couldnt make a point outside the surface. Got this message when I tried. Did the thing that revit told me and placed a point inside the surface and moved it..... GOT THE SAME MESSAGE AGAIN hahahahahaha!
But I tried to split the area where the interpolation was and that worked, so thank you! 🙂
Message 8 of 9
I can feel the warmth of that upside-down frown all the way  from here!!!  Wow! I think we even have lift-off.
Can you confirm lift-off mission control? Over and out.
Message 9 of 9
Mohamed-Nassar
Look at this Link it will help you and Good Luck
https://www.augi.com/articles/detail/better-site-coordination-and-topography-an-autocad-civil-3d-and...
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
