Problems with placing of horizontal dimension in sectional view.
I cant place the horizontal dimension in sectional view please heldd.jpgp me.
Alfredo_Medina
Welcome to the forum.
You say you can't place a dimension in a section view, but you show a view that has a dimension. Then, how can we know what the problem is?
Sahay_R
Two things
1) Are you using Aligned dimensioning? Aligned dimensioning looks for perfectly parallel reference to dimension between - if they are slightly off you will not be able to place the dimension
2) I see that you are in a sheet. Have you double clicked to activate the view before attempting to place the dimension?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Good eye!
Smiley Happy
When I am giving vertical dimension its possible but horizontal dimension its not coming here, I am using aligned dimension and its in sectional view not in sheet please help.
Sahay_R
Can you share the file?
Rina Sahay
FAIR59
Your Section / Elevation  is probably slightly off axis. If so , then the walls are not perpendicular to the viewplane, and you can't dimension them.
