Problems with exporting to DWG since switching from 2018 to 2020 Revit
Hello there Autodesk community.
I have a issue with exporting DWGs from Revit. I have a normal template I used all the time last year and it worked perfectly. Ever since our office upgraded from 2018 to 2020 Revit the template isn't working correctly.
The main issues are that its not exporting Hatches and Dimensions.
I have gone already through some stuff but couldn't find the issue so I hope someone might enlighten me whats changed in the 2020 version.
If needed I could make a local save and remove most of the stuff since the file is very large so people can check through the template itself...
PDF Export works without any problems or printing.
Curiosity: When I export with the option : Export views on sheets and links as external references both hatches and dimensions are in the DWG its just that there are a thousand files.
It would be great if I could make some progress till tomorrow else id have to redraw DWGs and we dont want that as Revit users x)
Thanks in advance!
