Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Problem with upgrading file from revit 2017 to revit 2018
giapanotis
giapanotis
Hello!
I have a model from revit 2017 and i want t put it in revit 2018.The versions that i have are for educational use.The laptop that i have is i3 also the desktop and the graphic card are also weak.When i want to upgrade i check the audit ,it is showing that the files are being upgraded but simply stops and doesnt open it.The files contain a lot of families that i have downloaded,the size is 45 mb.I have done the same procces with  a lighter model that was 35 mb and it worked!
Do you have any idea how to solve it?(i deleted some families t make it lighter but the result is the same).
Thanks a lot for your time.
What's your build? There is a 2018.3.3 available. Try applying the latest and greatest.
giapanotis
Thanks for the replying ,
I go to my account and i try to find the update that you mentioned and i can't find it!
I have downloaded the version of this revit this week ,so maybe, its already updated?
I am trying to open the desktop app and shows an empty window like this.
giapanotis
I finally did it ,i went to my desktop(i have already installed same version in 2 divices )and the desktop app was working fine!I installed the update and everything was cool!
Thanks!
