Problem with stair with "draw stair command"
I have problem with a rail.
I do that with "draw stair" command.
I do a long rail that go from level 1 to 4.
When finisch the scheth even if the contour are close and the riser are correct for the 4 level give me error (att 2).
If click on stair say me "angle pillars/upgrip could be not parallel to flight of stairs or landings
To have the same angle divided the boards in proximacy of the landings".
If click on railing "angle raling it will not be parallel to angle landing. To have parallel railing divided the segment on the landings".
Someone can help me, please?
.rvt file
PijPiwo
Split the stair boundary (pic 1) and fix the rail top host as per pic 2.
Thank's thank's thank's!
@PijPiwo if have the same problem but with "stairs by component"?
