- Mute
- Permalink
- Report
Hello All,
We are having a couple of problems with the spot elevation system family, and I was hoping to see if anyone out there has a solution or possible workaround to the problem. There are two issues:
The first issue is that the option to show the text "In-line with leader" becomes in active when a custom symbol is used with the spot elevation. This is a problem because it forces the user to manually position the text value of the spot dimension so it is properly centered with in the symbol. The symbol CAN be placed above or below the leader. Please see attachment #1.
The second issue is that when a symbol is used, and the spot dimension itself is dragged below the leader, the symbol being used flips or mirrors around the horizontal axis of the leader origin and appears upside down. Please see attachment #2 & #3.
I have tried playing around with the "keep readable" option, nested families etc, and have submitted a formal support request to autodesk, but all attempts to fix this have come up short. If anyone has any ideas, I'd love to hear it. Thanks in advance.
Developer Advocacy and Support +
