Problem with Reivt 2022 realisitic elevation views
konetarchitecture
konetarchitecture
I am experiencing a display issue in realisitic elevations with REVIT 2022.  It doesn't happen all the time, just randomly.  As suggested by Autodesk, I do open all my projects through the Revit desktop app and on occasion my elevations will become a dark grey color (not what they are programmed to be) and there is often a secondary outline of portions of the elevation(s).
I've set all of the views to PHASE: NONE and I still have this issue.  What am I supposed to do to remedy this?  Is Autodesk working on a fix?
I have a 2019 BOXX APEX S3.04 with 32 GB of RAM, but there is often a warning stating I need more memory???
Try Show Complete instead of None.
konetarchitecture
I'll try that and respond if it works.
Thanks.
konetarchitecture
Thank you ToanDN, I think that may have solved the problem.
RDAOU
If the issue is not solved, you may also stick to the same post you do not need to re-post it again...I am pretty sure that ToanDN would have continued to give you suggestions on how to fix it
Realistic View = Sun Settings (I will post you a detailed reply on your other post Link below)
https://forums.autodesk.com/t5/revit-architecture-forum/2022-revit-problem-with-elevation-view-showi...
