Problem with Realistic View in Revit 2022
Message 1 of 29
Realistic View is not showing anything (can't see surfaces, lines, etc)... when hovering over an element, the blue 'select' outline appears, but otherwise the 3d view looks empty. Shaded view and hidden line views work normally. I have tried deleting the general 3d view and regenerating it, but nothing changes. My PC has an AMD Radeon 6900 xt GPU and an AMD Ryzen 7 3700x CPU. Would greatly appreciate some help! Has anyone else encountered this issue?
Nate
Replies (28)
Message 21 of 29
This really saved me today!...Thank you so much @Anonymous .
Message 22 of 29
Ohh @Anonymous  thanks a ton! I tried everything and wasted a lot of my time to solve this. Finally this worked for me. Hope @Anonymous will come up with a permanent solution for this.
Message 23 of 29
Thanks, it really worked!
Message 24 of 29
rvet
i have the same problem can you help me ?
Message 25 of 29
la1806645
Please look at my reply to this post earlier, it will hopefully solve the issue.
Message 26 of 29
hallie6HHWH
Community Visitor
Community Visitor
Hello! Did anybody ever figure this out? Realistic View is a blank white screen, objects will highlight in blue. When you go to Enscape it also goes blank if you start enscape while in realistic view mode.
This sucks a big one!
Message 27 of 29
la1806645
Refer to my old reply as a solution to this, it worked for me.
Message 28 of 29
badjoudjv
Community Visitor
Community Visitor
the solution is ez and without a hotfix , just open revit 2022 , then open the project from the home screen (recent files) , that shoud fix the problem
Message 29 of 29
mogorosi
Community Visitor
Community Visitor
THIS WORKED! THANK YOU!
