- Mute
- Permalink
- Report
Hello, I have a problem with a polygonal window I created (picture 1) that does not look right in floor plan view. I made it by modifying a window from the Revit 2019 German library, it works perfectly fine except for this problem. It has an opening upper panel and fixed lower panel on the one side. The problem: When cutting through the upper panel, the cut profile will appear displaced on one side (picture 2).
When cutting through the lower panel again it doesn't look right (picture 3), even though this can be solved by setting the upper panel to be not visible in floor plan view (but still I don't understand why it happens). These panels are modeled as separate families and loaded into the window family. I want my floor plan to cut through the upper panel so that the opening symbol will be visible. I would appreciate any help/ideas.
Picture 1
Picture 2
Picture 3
