Problem with import of CSV.file to make topo
Even91
Message 1 of 9
Even91
Hei.
I am having a problem to import CSV.file to make a toposurface of it.
Have tried some of the suggestions on the forum but nothing seems to work out for me.
for example dot to comma
What can i try?
CSV.file atteched here.
Replies (8)
Message 2 of 9
jay_colc
You possible need to review the file as there are semicolons and Numbers as Text
It needs to look like this
How are you creating the CSV?
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 9
Even91
hey and thanks.
Do not know why you get it as there, but mine is like this.
Have used both dot and comma
Message 4 of 9
jay_colc
Can you send this file please
Jay Colcombe
Message 5 of 9
Even91
The file is attached.
Message 6 of 9
jay_colc
I opened a Blank Excel Sheet, Data Tab> From Text/CSV > Semicolon  Saved it out and deleted the header row
Looking down the list some of these number do not look right but is allowed me to import it into Revit but killed my Laptop and hung which i was expecting due to the variations in values in the columns but it did come in eventually
Jay Colcombe
Message 7 of 9
Even91
I tried the same as you now, but got the same result as before
Message 8 of 9
jay_colc
There is definitely something not right as i cannot repeat your images with that file and you can not follow my process.
Here is the file i can create a Topo with (this was generated from your file as above)
Jay Colcombe
Message 9 of 9
Even91
Thanks.
Had to manually make the x,y,z cordination in one coloumn on several rows and replace ";" with ",".
Worked fine with a new file.
