Problem with IFC Export - User defined property sets
Goodmorning, I have a problem with the IFC export setting (Revit 2018.3.1, 18.3.1.2 ).
When I try to use the options for export an IFC with his property set, in the output file all the loadable familes (doors, windows, furnitures..) are missing the parameters mapped in the property set.
I try to use both options of "Export user defined property set" or "Export schedules as property set"
Obviously for the first method i setted the txt file and in the second i created the relative schedule.
But in both ways what i have obteined was an IFC file with the correct Pset only for the system families (walls, floor, beams...) and I don't understand why. I have created the exports with standard IFC options.
I encountered this problem in italian version and also in the english version of Revit.
Any idea or suggestion about this kind of problem?
Thank you very much in advance
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community. I see that you are a new visitor.Smiley Happy
Sorry to hear that you are having issues with the IFC export.
Can you share a screencast , screenshots, Revit file and a journal to test further?
Looking forward to your reply.
Tester and having the same problem as described.
Viveka_CD
Hi @Anonymous
I'm checking back on this issue. it's been a while and I wanted to know if you had a chance to send us files to test further?
Also, are you using the latest IFC exporter?
Looking forward to hearing from you.
