Problem with generic wall and library
hey evryone i had a question about the library of  walls; because i have just only generic walls whitout layers,cavity or bricks. So my question is how to install library and where i can find the folder?
thanks a lot from a student from italy
tgrantdelawie
To my knowledge, there is no library that is automatically provided with Revit.
If you have existing projects to pull from, you can use Transfer Project Standards.
Some offices will build out their wall types in a container file (like a template but a RVT file) and then use Transfer Project Standards to populate into a project. Some offices include them in a project template (RTE file), but a ton of wall types becomes more troublesome than helpful as many of the wall types may not be used project to project.
You need to start with the Architectural (default) template which includes some basic wall types.  If you start with Construction or MEP it won't have any wall types.
There isn't a library to load as they are system families and are available in the project only, same as Roofs, Floors and railing types.
