Problem with curved wall, attached column and window
halfon.raphael
Message 1 of 8
halfon.raphael
I have a problem with a multi-layer curved wall in which I attached a structural column and placed a window.
The wall has a radius of about 800m so you don't see that it's curved but it is.
When I try to put the window at the border of the column, I get a warning, explaining that the column must be unattached. So i have to reduce the length of the window so that it fits between the two columns, but there is still a few millimeters of the wall between the column and the window. I would like this wall not to exist.
Has anyone dealt with this problem ?
Replies (7)
Message 2 of 8
No issue here so you might want to share your model.
Message 3 of 8
What do you mean by "attached a Structural Column"?
Message 4 of 8
halfon.raphael
Please find more details in the attached files
Best regards
Raphael
Message 5 of 8
halfon.raphael
could you open the files that I sent you ?
best regards
Raphael
Message 6 of 8
halfon.raphael
Hi @barthbradley , @ToanDN
could you open the file ?
Best regards
Message 7 of 8
Best regards
Message 8 of 8
