Problem With Curtain Wall individual grid lines
lynsher
lynsher
Hello everyone
im having this issue with curtain wall, it doenst let me select each grid line to modify the distance between each vertical mullion. Any suggestion? like u may see it just let me choose the wall courtain wall grids.
Thanks in advance
Edit the curtain wall type and change vertical grid to Maximum or Minimum space, or None for 100% free placement and adjustment of grids.
Can't select?
Sounds like Select Pinned Elements is unchecked. Check it.
ennujozlagam
hello, in addition, try to select the grid by using your keyboard TAB and unpin or edit type your curtain wall and set from there and see if helps. thanks
