Problem with Cloud rendering
aoziang
aoziang
Hi guys,
I'm having trouble with could rendering. My pc suddenly cannot start cloud rendering somehow. The same file and account is still okay for rendering on a different PC.Did any of you ever came across the same situation? Got any idea how to fix it?cloud rendering issuu.PNG
I have the same problem!
ennujozlagam
@aoziang hello, you can try to check it here some explanations in your problem this LINK. hope it helps. thanks
aoziang
Hi ennujozlagam
Thank you for the Link. I actually tested that link before, It didn't seem to work with this case. I even tried to reinstall the program, but also, not helpful.
ennujozlagam
@aoziang @Anonymous  hello, try to install latest updates and hot fixes from autodesk and clear your warnings as much possible and try again rendering., see if helps. thanks
aaa
Observer
Observer
@ennujozlagam
I'm pretty new to the software, may I ask by hotfixes, you mean hotfixes for Revit right? like stuff in this link: https://knowledge.autodesk.com/support/revit-products/downloads
ennujozlagam
yes, you can also go to to your autodesk account if you are under autodesk subscription and download from there.. thanks
