Problem with array
2 REPLIES 2
mrheuseler
234 Views, 2 Replies
Problem with array
Hello experts.
I'm having a bit of trouble with some array.
Need to control this "bar", so it follow my parameter "depth".
It is working before i make it "array", but after array, it stops working.
It needs to follow the ref. plane, that it has been locked to... But it doesn't work!
How can I control it?
Please see attached picture!
Hope you can understand what i'm trying to say here 🙂
Thank you,
Kind regards
2 REPLIES 2
in reply to: mrheuseler
Is this in a family?
If it is, then nest the Element to be Arrayed and control it's "depth" via a Parameter in the Host
If this is in the Project, it would probably be better to include the Ref. Plane in the Array Group.
