Problem Windows Preview + AutoCAD (from Revit)
Message 1 of 22
Hello guys,
There is a thing that is going on with the projects I'm working with. In Windows, on the side panel, it shows a nice and correct preview. But when I open it on AutoCAD, it shows a sheet being flipped/dissapeared.
Is there any way to solve this?
Note: The dwg file is exported fromout Revit.
Replies (21)
Message 21 of 22
Got it!
I literally tried everything to solve this issue, but there is nothing that can be done within Revit. The user has to manually change the dwg file in AutoCAD, which is terrible if you have a lot of sheets.
Solution: download Revit 2020.2 (I was working with 2019.2)
No idea what is different, but have a look at this link if you encounter the same problem as I do.
Cheers!
Message 22 of 22
PhLien
Observer
Observer
I had same error with Revit 2019.
I tried with Revit 2023 and this error was fix.
Did you have another suggestion without upgrade version?
