Problem Windows Preview + AutoCAD (from Revit)
21 ANTWORTEN 21
GELÖST
Nachricht 1 von 22
1378 Aufrufe, 21 Antworten
Hello guys,
There is a thing that is going on with the projects I'm working with. In Windows, on the side panel, it shows a nice and correct preview. But when I open it on AutoCAD, it shows a sheet being flipped/dissapeared.
Is there any way to solve this?
Note: The dwg file is exported fromout Revit.
21 ANTWORTEN 21
Nachricht 2 von 22
MostafaElashmawy
als Antwort auf: Anonymous
These items are the crop view. These will not show in print if you printed. They are put into a "don't print" layer. and that's why they don't show in the windows preview.
If you don't want them to be exported to CAD, do it in revit by unchecking "crop view visible" for all your viewports.
Mostafa Elashmawy
Nachricht 3 von 22
als Antwort auf: MostafaElashmawy
Thanks for your reply Mostafa.
You say "If you don't want them to be exported", but I do want them to export. The left picture in my first post is from the Windows Preview Pane and that is exactly how I want to see it in AutoCAD. Even Revit itself shows it correct when wanting to export it (with or without the crop region):
Nachricht 4 von 22
ennujozlagam
go to your view > adjust your crop region> tick crop region (properties > extents) > after adjusting exact view you want to see > uncheck crop region and export to autocad. thanks
Nachricht 5 von 22
als Antwort auf: ennujozlagam
Tried it, but the results are the same. Revit shows it perfectly, just as I want. But whenever I open AutoCAD, it flips the model.
But I noticed something important though. Check the screenshot:
Nachricht 6 von 22
ennujozlagam
is there anyway you can share the file so we can check. thanks
Nachricht 7 von 22
Uncheck "Export views on sheets and links as external references".
Nachricht 8 von 22
als Antwort auf: ToanDN
They aren't in seperated sheets. They are all in one model already, so that doesn't work @ToanDN
I'll see if I can get the AutoCAD (or Revit) file for you @ennujozlagam
Nachricht 9 von 22
ennujozlagam
better if you share the revit file because the issue come from there? thanks
Nachricht 10 von 22
@ennujozlagam I can't upload more than 75 MB. Can I mail it to you?
The file is approx 150 MB (I have no clue why).
Nachricht 11 von 22
ennujozlagam
you can use dropbox or wetransfer and send me the link and pm me the link here. thanks
Nachricht 12 von 22
ennujozlagam
maybe try to zip first and share here. thanks
Nachricht 13 von 22
Zipping it makes it 100 MB, still too much. I've sent you a PM.
Nachricht 14 von 22
ennujozlagam
Sorry I don't understand the wording. most of the families loaded are deleted and vertical gridline too ? I'm not sure if this is what you wanted to be? In AutoCAD you need to freeze the viewport. Thanks
Nachricht 15 von 22
Yes most of the things from out the project disappear. But that's just how we want it.
Everything shows great, except for that one viewport.
Locking in AutoCAD (how?) is not an option. Sometimes we have 100 sheets that needs to be exported to DWG.
Opening AutoCAD and adjust them all manually is terrible. Something should be done in Revit I think.
Nachricht 16 von 22
ennujozlagam
see screencast. thanks
Nachricht 17 von 22
Thanks a lot of the effort @ennujozlagam
The issue is: we use a tool to make a sheetlist from the project. These views are sometimes 100+.
Manually adding sections and adjusting every viewport will be a pain in the *ss.
Same goes for the output results in AutoCAD. Can't change them all one by one.
There is something in Revit, which has to be (un)checked or modified in order to fix this simple but annoying problem.
Hope you understand me.
Nachricht 18 von 22
ennujozlagam
at the moment no solutions for this automatic freeze the viewport in autocad once exported. you can refer to this LINK. thanks
Nachricht 19 von 22
Thanks @ennujozlagam
At least we tried. I'll keep this topic open if anyone has suggestions that might work.
Nachricht 20 von 22
ennujozlagam
no worries, wait for someone suggestion that may work? thanks :grinsendes_Gesicht::lächelndes_Gesicht_mit_Sonnenbrille:
