Message 1 of 10
10:48 AM
- Mute
- Permalink
- Report
I have two walls stacked vertically.
The outermost layer for wall A is a clapboards with 2'-10" of a different material at the bottom (I used the split region tool in the wall properties/structure)
The outermost layer for wall B is just clapboard.
When using the "join geometry" tool ... the clapboards won't join.
Not looking for work-arounds. I know about linework. I know about stacked walls. I know I can separate wall A into two walls.
The merge layer function is useless if affected layers can't clean join to the same material in other assemblies.
