Problem sharing Topography between Revit 2024 and Civil 3D 2024
peter.petschek
Message 1 of 13
peter.petschek
In Revit 2024 I use LINK TOPOGRAPHY, only TOPOSOILD is available.  It creates an error messages for my dtm.shared.dwg.  In Revit 2023 when I use the same workflow but Topography instead the same dtm.shared.dwg works fine. I guess the new Toposolid is causing the problem. The option Topography is needed.
Any suggestions?
Replies (12)
Message 2 of 13
What's the error message?
Message 3 of 13
1. Use 2023 until they fix 2024 toposolid.
2. Export Civil3D to a point file and create toposolid in Revit 2024 from Import.
Message 4 of 13
peter.petschek
Revit 24 does not import the dtm, because it has some overlapping lines. In Revit 2023 the same data where imported.
Message 5 of 13
peter.petschek
1. Revit 2023 - probably have to do that
2. I am talking complex dtm (see attachment). How would you control the triangulation at the edges? This is not a solution. Besides that the workflow between Civil 3D and Revit via ACC and shared.dwg worked before ... . Even in the Revit 2024 Help under Site Design the workflow is recommended ... , the choice Topography is missing. Toposolid causes problems, in case there are overlapping lines, etc.
Message 6 of 13
peter.petschek
See screenshot in the attachment
Message 7 of 13
peter.petschek
No more response, ideas or solution to my problem?
I reinstalled Revit 2023 and teach with it in the meantime.
By the way:
Revit 2024 Help, Sharing Topography between Revit and Civil 3D also still explains the old workflow with topography.
Message 8 of 13
peter.petschek
No news on the problem?
Looks to me like an major bug.
"Sharing Topography between Revit and Civil 3D" as explained in Help, Revit 2024 does not work!!!
Message 9 of 13
peter.petschek
I reinstalled Revit 23 and Civil 3D 23, I use the Desktop Connector 16.3 and the ACC with full access rights.
Since this month I receive the message also in 2023 "The topography data does not contain usable surfaces" (see attachment). It worked fine in June, a whole class of students used the workflow ... .
Maybe the problem is in the ACC?
Message 10 of 13
peter.petschek
Solution to the problem to deal with Revit toposolids:
ifc 4.3
Export the terrain in Civil 3D with Infra IFC 4.3 (export landxml, create a "clean", new drawing, import landxml and export with ifc 4.3). Link ifc 4.3 in Revit, bind and ungroup it, etc.
@Anonymous: Please adapt your workflow SITE DESIGN under Help in Revit 2024. We C3D site designer don't want to deal with Revit Toposolids ... . C3D can do a much better site design job for BIM construction!
Message 11 of 13
peter.petschek
New problem:
Revit 2024 shows an error message (see attachment) when one tries to import an ifc 4.3 file using Ifc 4.3 Extension Update 1 (1.3.24) in Autodesk Civil 3D 2024.3.
Message 12 of 13
bails1974
I am having serious issues with this Link Topograhy just not working.  I have tried multiple "fixes" but I just need the feature to work properly as it did up until Revit 24. We use this feature on upwards of 100 projects up to REVIT 24. On  new REVIT 24 we have to have the surfaces in Revit 23 and linked in. Can Autodesk not allow a toposurface to be made from a linked C3D surface model rather than a Toposolid?
Message 13 of 13
peter.petschek
I agree!!! We, who are using Civil 3D and Revit, need the option between Topography and Toposolid. I was the AU last year and talked to Revit people. They were so convinced about Toposolid. Me, as a C3D user, I was just thinking thank you ifc 4.3  😀
