Problem room areas
1 REPLY 1
147 Views, 1 Reply
Problem room areas
When I start a project, I set up my Room tags to show the areas. As soon as I start adding detail to the drawing eg. water features, openings, niches ex. some rooms show up as "not enclosed". Is there a quick way that Revit can show you where the Room separations are calculated?
1 REPLY 1
Highlight the room tag, and the boundary will display....but if it's coming up 'not enclosed' you wont see anything. You can use room separation lines to define those areas such as openings where rooms should be enclosed. "Jenb" wrote in message news:23080997.1102316042941.JavaMail.jive@jiveforum1.autodesk.com... > When I start a project, I set up my Room tags to show the areas. As soon as I start adding detail to the drawing eg. water features, openings, niches ex. some rooms show up as "not enclosed". Is there a quick way that Revit can show you where the Room separations are calculated?
Autodesk Customer Advisory Groups
