Problem in uppdate
1 REPLY 1
husamcivil
217 Views, 1 Reply
Problem in uppdate
husamcivil
Hi all I have revit 2019 when I need to update  some content like Euro code steel profile
this error will display
attach. error massage
Problem in uppdate
1 REPLY 1
aRcHiTeCt.JM
in reply to: husamcivil
aRcHiTeCt.JM
... sometimes with autodesk is like that... you have to try again for a couple of times..
.. or try to download the content of those codes and then install them
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
.. or maybe you have to allow the conection in your firewall
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
aRcHiTeCt.JM
REVIT EXPERT ELITE
