Problem importing Cad files in Revit
enji.sorial
Message 1 of 8
enji.sorial
I am having a problem importing the attached files in Revit; the lines are jagged. I tried purging, auditing and exploding blocks, but in vain. I need help importing them with straight lines.
Replies (7)
Message 2 of 8
jacques
I can't process RAR files. Can you reupload as ZIP file?
Message 3 of 8
It is likely has something too far from 0,0,0. Zoom Extent and see.
Message 4 of 8
jacques
What he said. Your point of origin is 2000km away. Keep it under 10km
Message 5 of 8
enji.sorial
I moved the objects to 0,0,0 and still I get the same. I even copied it to another file.
Message 6 of 8
jacques
Can you post the clean file ie… the file you are actually importing?
Message 7 of 8
enji.sorial
This file is one I cleaned and copied in another empty file. In Revit, some lines are straight and some aren't.
Message 8 of 8
Corsten.Au
Hi
Can you test simple details lines at certain angles.. like ( 1 deg, 0.5, 0.8 degree etc )
are you getting these kind of jagged lines..?
and whether imported CAD / Linked cad showing they same behaviour?
default lines at certain angles...default lines at certain angles...
Corsten
Building Designer
