Problem framing, generic model and Underlay
Message 1 of 19
Hi there,
I'm wondering if there is a limitation that prohibits generic models and framing members beign shown in the underlay? Or perhaps I have my underlay set wrong and its not showing for another reason.
-All phases are set to Show All/ New Construction
- View range and under lay are set as shown in screen shot
Any help would be appreciated.
Replies (18)
Message 2 of 19
Is the Category turned on and the View set to something other than Wireframe?
Message 3 of 19
yes I've tried in hidden, shaded and realistic, and other parts of the
generic model and framing are showing. Oddly, the lighting attached to the
framing members are showing, and part of one framing member at the apex of
the roof structure are showing too.
Message 4 of 19
Well, there is no limitation that come to mind.  Can you post your file?
Message 5 of 19
Thank you!
finalmode.rvt
Message 6 of 19
No file attached.
Message 7 of 19
Ah yes, just had to reduce the file size
Message 8 of 19
I'm not readily seeing an issue. What am I looking for?
Message 9 of 19
I'm trying to make the overhead lines visible using an underlay so that I
can mark them (with linework) for my floor plan. I can't make the full
extent of the overhead lines show, so I've asked for help. What's more
confusing is that some elements that are overhead (the lights) are being
shown, whereas the structural framing members and tensile material are not.
Can you assist?
Message 10 of 19
Check "Show Pre-Cut in Plan Views" in the Structural Framing Family
Message 11 of 19
Hmm still doesn't come up in the underlay, any other suggestions?
Message 12 of 19
*Sorry to clarfy, the tensile material still doesn't come up in the underlay
Message 13 of 19
"Show Pre-Cut in Plan Views" works here...
Before:
After:
Message 14 of 19
Is this what you are after?
If so, raise the Cut Plane.
Message 15 of 19
Well I am try to generate a drawing that shows everything above the cut plane as dotted lines as per convention. Is it not possible to show objects below the cut plane as solid and then as dashed above?
Message 16 of 19
Can you post a sketch that shows how you would like it to look?
Message 17 of 19
You cut plane cut through the tensile so they will not show as Underlay. Underlay only shows elements not captured by the view's primary range.
What you need to do is create a ceiling plan, VG to override the tensile to show dashed, and place it on the same sheet as the floor plan.
Message 18 of 19
Thank you both for your time
Message 19 of 19
