PROBLEM EXPORT DWG UNITS
Hello
The DWG Export from Revit has a problem because it changes the units of autocad parameter but not the command DWGUNITS.
So no problem in Autocad or Autocad LT but problem when we are under AutocaD Architecture or MEP
DELSAUT Alexis
Guillaume.Chazal
Autodesk Support
Autodesk Support
Hello Alexis,
Thanks for your message.
We indeed received other reports regarding this issue.
This has been registered on the development team side for further analysis.
You’ll find below a video that describes the issue and a workaround (at the end of the video).
Basically, the workaround is to change the units of the drawing in Autocad MEP and to refuse the auto scaling.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Best regards
Guillaume Chazal
I accept your solution but this post don't repair the problem with REVIT, But this command in autocad it so faster.
(command "-dwgunits" "6" "2" "2" "N" "O" "N")
Best Regards
DELSAUT Alexis
