Problem between depth view in view range
I do not undrestand perfecly the command View Depth
It a com
It a command that can do to view in function of the offset I set from base level
I do two floor: 1 on -1 level and 1 in level 0. the distance from one to other is -3.1
If modify the properties of view depth in view range in level 0, If I put 0 in offset box I didn't view the floor below of level -1 , if I even just
 -0.1m in offset box that show me all the floor.
To view all the floor cannot I set at least a dimension greater of -3.1 (the dimension from two level?
Thank's
Thank's
Thank's
Sahay_R
See my response to your other thread.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
