Printing sheets from Sheet List
StephMarsh
Message 1 of 13
StephMarsh
I have sheet lists in my project. I can sort the sheet list using parameters. This way my list shows like I need it to.
For example I have my T-series then my Z-series then my A-series.
How can I create a sheet set to print from my sheet list?
Thank you
Replies (12)
Message 3 of 13
StephMarsh
Thank you. I did see that.
I don't think it is available anymore.
Can you send link?
Message 4 of 13
Message 5 of 13
StephMarsh
Looks like that may be a great thing.
Where do I get the download?
Message 6 of 13
The Link I posted has an embedded Link that goes right to the download site.
Message 7 of 13
StephMarsh
I think this is what I need!!
Thank you very much.
Message 8 of 13
Message 9 of 13
Message 10 of 13
kathleen.mcconnell
Community Visitor
Community Visitor
Revit 2022 issue: My sheet lists on the cover sheet is not displaying as split lists that display correctly on other users local and CENTRAL models. This only happens on my work station where Revit 2022 was recently reinstalled. Are there setting missing on my computer?
Message 11 of 13
Mike.FORM
If I understand correctly, you have a sheet list schedule on a sheet and you want it split using the split schedule feature. It is displaying correctly for other users within the same central model but it is not showing split for you?
Have you tried removing the schedule and putting it back on the sheet? Do other schedules on the same sheet have the same issue? Have you synced to central?
Message 12 of 13
kathleen.mcconnell
Community Visitor
Community Visitor
I have sync'd with Central and other team members have as well andso we are all up to date with Central. The lists are split and fit nicely on the sheet. However, my sheet is displaying as if the lists are not split and are identical.
my model
This is the same sheet on a different computer split and are listed in the properties correctly
Any suggestions would be greatly appreciated
Message 13 of 13
Please create a new topic because your question has nothing to do with the original question.
