Printing as PDF in Revit 2014
How do you print as a PDF when the drop down only provides the printer or FAX as an option? Is there a way to load PDF as an option if it's not already there?
What do you normally use to create PDF's?  If you're in a bind, go grab a trial of Bluebeam Revu.  They have a great plugin and driver for Revit.  The trial is for 30 days.
I normally just print through the Revit program itself. Typically, when  you click print, there's a drop down option that says PDF. When you go to print, it automatically saves it as a PDF. But I will give your suggestion a try, thank you!
If it is from the same computer then your PDF printer has been removed. You can get a free one such as PDF Creator. They do not have all the features like Bluebeam or Acrobat but they will do the job of printing from any programs to PDF.
Thank you so much! That worked perfectly!
