Print with unreferenced tags via Naviate in RVT
Tarek.El.Ali
Message 1 of 8
Tarek.El.Ali
I have some unreferenced callout that I would like to show when I'm printing through Naviate (Batchplot). At the moment you can only select/unselect this through Revit's print setup but not through Naviate.
2020-10-28 10_05_47-Window.png2020-10-28 10_07_08-Window.png2020-10-28 10_07_43-Window.png
Replies (7)
Message 2 of 8
_Vijay
you need hide are you need to show the tags in printed sheet?
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 8
Tarek.El.Ali
I want to show them. But I print through Naviate.
Message 4 of 8
RobDraw
When you uncheck the box in Revit, they still don't print? Does Naviate allow you to choose a print set-up saved in Revit?
Rob
Message 5 of 8
Tarek.El.Ali
When I uncheck the box, they show. But I print through Naviate for a batchplot and I haven't found a similar print setup in Naviate.
Message 6 of 8
RobDraw
You didn't answer my question.
Rob
Message 7 of 8
Tarek.El.Ali
Yes when I uncheck in Revit they print. I don't know if Naviate has a similar print setup, I can't find it.
Message 8 of 8
RobDraw
We are talking about Naviate. What does Naviate use for print set-ups? I would think there is some way to use saved settings from Revit.
You really should looking to Naviate help, support, or forum.
Rob
