Print to pdf
Print to pdf
Print to pdf
How do I print to pdf from revit 2018?
novesvalentin
Hi @Anonymous,
There are many topics about this in this Forum, you can search or you can also use the link below with the formal explanation:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
If this helped solve your problem please mark it as solution, so other users can get this solutions as well.
Valentin Noves
BIM Manager
www.valentinnoves.com
Click on Print and select the PDF  in the Print Name dropdown box.
Corsten.Au
Hi
Install a PDF printer like
1. Adobe Acrobat
2. Nitro
3. CutePDF
If nothing is available then check default " Microsoft Print to PDF"
PrinterPrinterTHere is a restriction of Print size, for example maximum size PDF possible is A3.. in that case use the reduction percentage and create PDF..
This table might help you... For example Converting A1 Sheet to A3 size pdf, 50% reduction is required... you may use
the combination which suits your project sheet size...
Size A3 A4
4A0 18% 12.50%
2A0 25% 18%
A0 35% 25%
A1 50% 35%
A2 71% 50%
A3 100% 71%
A4 141% 100%
A5 200% 141%
A6 283% 200%
A7 400% 283%
A8 566% 400%
A9 800% 566%
Best luck
Cheers
Corsten
Building Designer
@Corsten.Au: Ever use My Super Duper Excellente Revit to PDF Printer?  Smiley Wink
Corsten.Au
@barthbradley Thats looking awesome... Never got a chance to use that..
So many options in printing... just that users are locked sometimes with the companies default system.
I was luck to have Adobe Acrobat, X-Rev and few more...
Corsten
Building Designer
georgehobel
You could be fined for cultural misappropriation of language for that title....
George Hobel
Reflections of Charlotte
Residential Building and Design
