Print to PDF, Linked DWG Colors Changed
yasin.bosnali
yasin.bosnali
Hi.
I got a Revit 2020 file in which DWG files are linked in it.
When I try printing to pdf, some colors changed on pdf. Normal Revit view has true colors.
I tried to change from vector to raster.
Colors solved but resolution problem is huge.
Any idea?
Please help.
I encounter the exact same problem. Did you find a solution?
yasin.bosnali
Unfortunately no.
Is there a solution to this? same problem rvtt 2019 print preview is ok, pdf b/w...
yasin.bosnali
Not yet.
syman2000
nmarcelis
like sysman said, try installing the hotfix. I never encountered this problem in Revit 2020
Revit Certified Professional Architecture, Structure and MEP.
