Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Print sheets to PDF with Metadata
3 REPLIES 3
1171 Views, 3 Replies
How can I print Revit sheets into PDF documents and include sheet parameters in the PDF metadata. We need the metadata to browse the files in Explorer and for our Document Control software.
3 REPLIES 3
Anton.Czerwinski.1965
I believe that Revit does not support publish PDF with metadata directly. The way to get the metadata is by using an plugin that runs inside Revit. We have managed that by enabling metadada inside the Docuflow pdf tab. That app is available in the Revit app store as a free trial. You can see if that does what you want. In the image under you can see how you can enable the parameters export as metadata. We love the possibility to save the REvit document path of the in the PDF as metadata.
in reply to: Anton.Czerwinski.1965
Amazing! It works exactly as we want. 👍
Perfect. Dont forget to mark the answer as a solution. Thank you!
